KRC1 Software Limit Switch +A3
happytriger2000
文章: 8
註冊時間: 2016年 2月 8日, 09:26
文章 由 happytriger2000 »
一開機救出現這問題:
KRC1 Software Limit Switch +A3 error message 205
Emergency Stop error message 1
A1 to A6 不能JOG, 如果在Machine.dat 裡把 $SOFTN_END & $SOFTP_END 範圍改打大一點能解決嗎?
Re: KRC1 Software Limit Switch +A3
可能是A3的位置跑掉!
Try to Unmastering A3 and then Mastering A3
happytriger2000
文章: 8
OK, Umaster A3, 然後Master A3, 解除 error 205.
Error 1還在..
Check the hardware connections.
happytriger2000
文章: 8
Low battery該換電池:
另外X11wiring不對,應該是這樣:
happytriger2000
文章: 8
眼花...!:
BRAVO!!!
Jamesuplix
文章: 2
註冊時間: 2017年 5月 12日, 01:01
KRC1 Software Limit Switch A3
文章 由 Jamesuplix »
The spring tensioner got lost during shipping. Where can I get a limit switch? What is the part number?
I suggest you to contact your original dealer for the parts since they should have the robot parts documents, in which you can find the parts no. and make an order from your dealer.
