Power Source for Motoman MH3F
YASKAWA機器手臂/ YASKAWA Robot
文章: 342
I just get the Motoman MH3F imported from Japan and its controller is FS100. The problem now I have is that "Can I use 220V AC single phase instead of three phase as the power source for it?"
文章: 342
Re: Power Source for Motoman MH3F
After checking the plate on the FS100 controller, I found that power supply can have two choices: 3-Phase AC200/220V or 1-Phase AC200/230V. So I use 1-Phase AC200/230V as the power supply and the robot runs normally.
