3D曲面光學量測AOI系統
文章: 340
3D曲面光學量測AOI系統
3D曲面光學量測AOI系統
適用於3D曲面光學量測,如量測3D曲面玻璃的折射、反射係數、膜厚等光學參數。量測時搭配2隻機器手臂作同步動作、進行量測,機器手臂的運動路徑,均由軟體依據曲面幾何形狀及使用者預先點選之量測位置,經計算後自動生成,不必具備機器手臂程式撰寫能力,也能輕鬆上手完成3D光學曲面自動量測。
Robotic software for measuring optical properties of 3D curved glass:
How to measure the optical properties of a 3D curved glass is always a headache problem in the industry, not even to mention a method of automatic optical inspection(AOI). Wise-Tech Robot are the pioneer to develop this creative software to manipulate two robots for AOI of 3D curved glass.
The user only have to do is to pick up the measurement points on surface of the 3D simulated curved model, i.e., the location of the curved glass requested for measuring, and then the software will create program for both of robots. No coding is required for completing this job.
Features:
1. Applicable to 3D curved glass, LCD panel
2. Support for Windows 7 or newer
3. Support for KUKA KSS 8.2 or newer
4. No coding required
Software: Wise-Tech Robot
機器手臂:KUKA KR 6 R900
文章: 340
Re: 3D曲面光學量測AOI系統
1. 支援Windows 7以上作業系統
2. 適用KUKA KSS 8.2以上版本
3. 適合玻璃、面板3D曲面光學AOI量測
系統開發:卓智機器人Wise Tech Robot
