A. Basic inspection/基本檢測, yearly
B. Data Back-up/資料備份, yearly
C. Minor Electrical maintenance/初級電器維護, 每2年/ every 2 years
D. Major Electrical maintenance/高級電器維護, 每5年/ every 5 years
A. Basic Inspection/基本檢測
- 1. Evaluation degree of fouling/評估機器手臂污損程度
- 2. General visual inspection to check that connections are undamaged and fitted securely/ 電器接口檢查
- 3. Checking of running noises/動態噪音偵測
- 4. Checking of grounding concept/接地檢測
- 5. Visual inspection of the radial fans/風扇運作檢測
- 6. Storage of user programs/程式備份
- 7. Checking the emergency stop at the robot system/機器手臂急停裝置檢查
- 8. Checking of joint mastering/機器手臂零點校正
- 9. Condition and tension check of the toothed belts/ 皮帶張力檢測
- 10. Exchange of the toothed belt of axis 5 and axis 6/ 更換A5, A6 皮帶
- 11. Fixing of the maintenance sticker and documentation of the works on the servicing check list/ 填寫原廠保養工作單並貼上保養年份貼紙
- 1. Creation of a hard drive image/建立備份
- 2. Mirroring of the hard drive inclusive archiving/硬碟整體備份
- 3. Installation and functional test of the hard drive/ 硬碟讀寫功能測試
- 4. Labeling of the hard drive and handover to customer/ 標註硬碟儲存內容
- 1. Visual inspection of cabinet/控制箱檢測
- 2. Cabinet cleaning as needed/控制箱清潔(視實際情況)
- 3. Battery exchange/ 更換電池
- 2. Exchange of the PC radial fans/更換 PC風扇
- 3. Exchange of the cabinet radial fans/更換控制箱風扇
- 4. Exchange of the mainboard Battery/ 更換主機板電池
卓智機器人
